4SFEDZ
12-16-2006, 10:17 AM
the car is a 94 z28, but the line runnin into the reg doesnt mount back where it did with the stock reg. its about half an inch to far back. it goes into the reg just dosent bolt down with the other one. anyone else have this prob, what did you do?
byrons1502
12-17-2006, 07:46 PM
built a small bracket that allows the line to be bolted down. the regulator is way to big. be carefull the adjustment screw is easy to break, ran for a long time and no probs
speedygonzales
12-25-2006, 12:09 PM
If yours was like mine, the box was missing the necessary components that are provided by Aeromotive to mount it properly.
Look here:
http://www.aeromotiveinc.com/pdf/13107.pdf
When done with their components, it only requires a hole drilled
Contact them and they will send the parts you need quickly.
Then after you start using it and it fails, like nearly everyone elses, you'll go back to stock.
They suck, do you want mine?
byrons1502
12-27-2006, 02:37 PM
what a crock of crap. that was good to know. i had missing instructions and the other pieces. when i called the tech line they said that was how it was supposed to bolt
