northdakota93z28
12-14-2006, 10:14 PM
i have all kinds of codes at most times the last time i pulled them i had 12 codes, i am told they call them ghost codes i am replacing my pcm and i hope that fixes it i am wondering if anyone has heard of this if so any help is great thanks:confused:
Injuneer
12-14-2006, 11:33 PM
Multiple codes can often be caused by faulty engine and PCM grounds.
byrons1502
12-17-2006, 08:45 PM
check the powers and grounds to the computer. just because they are tight does not make them good. common for multiple codes. cheapest fix also
northdakota93z28
05-05-2007, 03:56 PM
i cleaned all the ground and the codes are still there i will try a ecu and see what happens my bud is a parts man so i can get 25 percent off still 225 is alot if it doesnt fix it.
shoebox
05-05-2007, 04:56 PM
Did you clear the codes? Most will not clear by themselves. What are you using to read them?
northdakota93z28
05-05-2007, 07:04 PM
i jumped the connector it took a bit before the codes came back because my fan stayed off for like 3 min but after that they came on again and whenever i start if they come right on. my understanding is they come on when there is hard codes.
northdakota93z28
05-20-2007, 10:42 PM
i am wondering if these ghost codes are making it so i cant shift into over drive at w o t ?
northdakota93z28
06-26-2007, 09:58 PM
i am buying a ecu from chevy for 250 so i hope it fixes the ghost codes i will tell you what happens when my new ecu comes.
