First Gear Lockout question (window switch)
I was checking out this window switch http://www.nitrousoutlet.com/catalog...product_id=964
and I was curious as to how the first gear lockout works on it. Do you have to reset it each time or what???
The Gear Lock Out feature works by sensing the rpm change in a shift and will not allow the system to activate untill it reads that rpm change. No matter what gear you are in when you arm the system and have the feature turned on it will lock that gear out until the rpm change is read. The feature will only reset if you turn the power to the box off and then turn it back on again.
-Chris
-Chris
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
Jul 4, 2005 05:00 PM
