1988 RX7 w/ 350sbc
Sneakin Deacon
12-12-2006, 10:58 PM
010 high nickel 350 block
aftermarket cam (hydraulic)
Mallory ignition
holley 750 double pumper
grannys install kit
Th350 w/ high stall
summit "4n1" tach (volt/oil/temp)
powermaster starter
hedman mid lengths
true duals into 18" Dynomax Bullets
torker 2 intake w/ 1" spacer
-8AN fuel system
sumped fuel tank (coated aswell, 1yr warranty for no rusting)
holley black fuel pump
holley dead head regulator
-8AN carb kit
electric fan
moroso electric water pump
4 brand new tires
will go 10's on a 150 shot
4000 FIRM...no haggling.
car just recently bent a valve, car runs but will need it replaced...under $100 and a few hours of work for a 10 second car. interior is 8/10 the dash being the only problem (missing center radio console section) and the exterior is probably a 6/10, the body is straight, but it needs paint and a cowl for the hood.
located in Tampa, FL
