160* thermostat and PCM program
Old Dec 9, 2006 | 05:46 PM
RxNupe's Avatar
Is it necessary to buy Hypertech programmer to changing fan temp power-on? I want to purchase 160 temp thermostat but it doesn't make sense if you don't change temp at which fan comes on.
Old Dec 9, 2006 | 06:14 PM
blackrat's Avatar
try and find a performance shop around you that can alter your pcm for a small fee. the hpp isnt worth the money. i had my fans programmed for 20 bucks. and while you dont HAVE to set the fans lower, its definantly recommended for the most benefit.
Old Dec 9, 2006 | 06:29 PM
2001NBMZ28's Avatar
It's not absolutely "necessary" and I'd stay away from purchasing a HPP3 just for fans, unless you can find one used for cheap. You will run a little cooler at highway speeds with a 160. Already got a 180 in there, see you're in Evanston - if you're just looking to run cooler in the summer you can always purchase a manual fan switch. Also the gauge will read about the same, I have a 160 and temps set pretty low and stays just under 210 when warm unless it's really cold (by Florida standards).
Nayr
Mar 3, 2023 08:34 PM
95_lt1_z28
Aug 30, 2015 06:17 PM
whitehooptie
Aug 10, 2015 07:02 AM
MikeWhitener
Aug 2, 2015 06:17 PM
88IROC_Z
Jul 22, 2015 11:38 PM
