stout basically new 95 t-top z28 auto car low 12's car 2000 miles since rebuild
Up for sale is my just redone last year 95 chevy camaro z-28. I bought this car in 04 in need of a transmission. Since then it has received just about everything you can imagine. This car is perfect for someone who wants a very fast car but is not a mechanic it is all done. Just needs new paint & wheels. I have put about 6000 miles on this car since I finished it & am selling now because I need the money. This is a t-top car. With a fresh interior. A freshly rebuilt engine & transmission. Plus all new suspension & about every performance part you can add. I took this to the track 2 months ago & ran a 12.6 on street tires & I believe it still has more in it. I work for a engine distribution company & this engine was hand built for me by a 20 year performance engine veteran. It was built to be run on nitrous although I have never set up nitrous in the car that was next but I am out of money. There is over 12000 in this car now I know it will not sell for what I have in it. It would probably cost someone that can't turn a wrench close to 20 grand to do everything I have done to this car. So my loss is your gain. Please email with any questions. The car must be picked up within 7 days of auction close. It is not available for shipping unless you have someone come here to p/u & no emails about certified check scams please(I hate those guys). Anyway bid on my car & get a very fast very well built ride for much less then what it is worth.Thanks for looking
Parts installed on car as follows:
1996 4 bolt main corvette block
Shot peened stock rods with arp rod bolts
speed pro forged standard pistons(block was not bored)
mild port work on stock heads
manley valves
lt4 hot cam kit(camshaft,springs,roller rockers,titanium keepers)
port matched intake manifold
new edelbrock 58mm t-body w,new sensors
new motorsports 30lb injectors
adj fuel press regulator
edelbrock short headers with egr removed(passed md emissions 1 month ago)
march short pulleys
new balancer
new water pump
new optispark distributor converted to late vented type
magnaflow 3" high flow cat
magnaflow catback exhaust
new suspension bushings front to rear
all front suspension parts sandblasted & painted
kyb adj struts on all 4 corners
new brakes,rotors & calipers up front
new pads on rear
lakewood lower control arms(not installed on car)
1le intake elbow
granatelli motorsports mass airflow sensor
moroso cold air kit
lt1 edit with pcm4less tune included on disk plus cable for tuning(no laptop though)
black interior from a wrecked 02 camaro with firebird seats
new autometer gauges(air/fuel gauge is not hooked up)
all new sensors just about on engine
new rebuilt transmission with 2800 stall converter
shift kit installed in trans will hold any gear until you shift it
I think that is all as you can see alot of money went into this rebuild I had the intention of keeping this car for a long time but now I need to sell it. So I did not skimp on anything I bought when building this. The trans was built by accurate transmissions in illinois & I personally spoke to the builder who installed the kit it shifts like a dream & will bust the car sideways going into second & chirp third if you are in it hard enough. This is a fast car fast fast fast not a daily driver so do not by it for that it has a very bumpy idle with the cam this is a great friday track car & gets about 18 miles to the gallon still but a little annopying for everyday driving. Once again any questions feel free to ask or call me 240-216-0063
manley valves
march short pulleys
new balancer
new water pump
new pads on rear
1le intake elbow
moroso cold air kit
