L.E.D. Lighting system?
CamaroZ282008
11-30-2006, 01:50 AM
Do you think it should be an option for L.E.D. Headlights along w/projectors on all Camaro models? Like being able to order a bone stock v-6 with higher end head and taillight set up? I've seen the L.E.D.'s on the new 350Z head lamps and they really look classy and set the car off. What about L.E.D. taillamps , would you want you're new Camaro to have them? I think they make the car look cleaner, more advanced obviously and more sophisticated. Maybe it woulden't be right on a Muscle car...tell me what you think.
johnd651
12-04-2006, 08:32 PM
id hope that like almost standard...i mean its brighter/stronger/cleaner/effiecient
ehh...i dont know...well know sooner or later
CamaroBoy96Z28
12-04-2006, 08:56 PM
Should be an option and standard the higher models if not all of them.
Z28x
12-05-2006, 12:59 PM
Should at least be standard on V8 Camaros
GoCamaroGo
12-06-2006, 10:55 PM
LEDs all around! The taillights that use LEDs instead of bulbs have a much quicker response for braking and the split second is important for older drivers that have a perception-reaction time longer than 2.5 seconds.
BradcTA
12-07-2006, 11:15 AM
Along as it has HID headlamps I will be happy.
OctaneZ28
12-07-2006, 01:58 PM
I think it would be nice if HIDs & LEDs were an option.
I'd probably spring for it.
90rocz
12-08-2006, 12:16 AM
Will HID's comply with the "Glare" regs on production cars??...
I heard they were getting tougher on extremely bright headlights..
Maybe they can lightly tint the headlight enclosures??...
SCNGENNFTHGEN
12-08-2006, 02:07 AM
Should be modern lighting all around the car IMO.
90 Z28SS
12-11-2006, 11:00 PM
LED headlights like the concept had would be completely out of the question . They are just now starting to show up in concepts on high end lux cars as a possiblity down the road .
I will be very upset if they lose the look of the headlight the concept had though . Which means a projector headlight , surronded by the halo . The mustang like traditional headlight reflector in the Bumble Bee Orange car looks really bad imo . Some very low end cars even have HID now . There shouldnt be any reason they could not use the adaptive Bi-Xenon(high/low beam HID in 1 bulb ) projector out of the Opel Astra headlight or the Bi-Xenon DTS projector , as at least an option . For a standard headlight , the Caddy DTS uses a single bulb and has halogen base headlights , Use that projector . They got plenty-o parts bins to pick from on HID's parts and different halogen and HID projectors housings .
jcopelan
12-12-2006, 11:25 PM
I don't see why they wouldn't use the projectors and HID right from the vette
90 Z28SS
12-12-2006, 11:39 PM
The vette projectors are designed with a separate projector for the high beams and the reflectors are designed to be used as such . The Camaro uses 1 projector which would need a Bi-Xenon specific designed projector housing , which is small selonoid contolled shutter within the housing that refracts the light from 1 bulb into a high beam pattern . The only GM cars I think that have this is the DTS , XLR and the Opel Astra , all the other GM cars with HID Im pretty sure all use a projector low beam and a traditional non-projector halogen high beam reflector ..... CTS , SRX , STS , Escalade , Outlook , Saab 9-3 for example .
jcopelan
12-13-2006, 12:37 AM
Ahh I gotcha. I never actually looked too close at the concepts headlights. I'm basically from the school of "give me a monster V-8 in a nice looking body, make it affordable, and stop overanalyzing everything" lol.
