Speedometer/Transmission Wiring Harness
Old Nov 28, 2006 | 01:23 PM
1996z28m6's Avatar
Where can i buy a speedometer/Transmission wiring harness?
1996 Z28 M6 T56
Old Nov 28, 2006 | 01:37 PM
davidarel's Avatar
umm, what exactly are you needing? The trans harness is integrated into the engine harness.
Old Nov 28, 2006 | 01:38 PM
1996z28m6's Avatar
the speedometer sensor got ripped out during a clutch install, and its messing up everything from odometer, to a/f ratio.
Old Nov 28, 2006 | 01:41 PM
bingo's Avatar
So you need a pigtail with the connector for the VSS? It is the same plug as a coolant temp sensor. These are availible at most parts stores.
Old Nov 28, 2006 | 01:45 PM
1996z28m6's Avatar
so all ill have to do is splice the wires to that new pigtail and itll work?...just to make sure the wires got pulled out of the plug.
Old Nov 28, 2006 | 01:48 PM
bingo's Avatar
Yes.
Old Nov 28, 2006 | 02:01 PM
davidarel's Avatar
just make sure you get the colors in the right pins.
Kix
Sep 8, 2002 06:30 PM
gh0st
Sep 1, 2002 10:24 AM
Teal94V-6
Aug 31, 2002 09:21 PM
CobraEatr
Jul 23, 2002 06:32 PM
