How do I do a Front End Alignment myself, I have acces to a alaignment rack...
Old Nov 22, 2006 | 06:45 PM
Need4Camaro's Avatar
There is an Alaignment rack at school with all the necessary computers and equipment and I can perform a front end alaignment myself. The instructor said it would be no problem under one circumstance... I must know how to do it WITHOUT his help. So I'm posting, How do I perform a front end alaignment? My steeringwheel is cocked to the left when I'm going straight and the tires are wearing all over the edges rather than the center...
Old Nov 22, 2006 | 10:35 PM
blacknsilverz's Avatar
do you have the gm f body alignment tool if not i would not try it you might make it worse sorry to say .
Old Nov 22, 2006 | 11:43 PM
I see, thanks...
Old Nov 27, 2006 | 07:53 AM
GreenDemon's Avatar
Your problem seems to be mostly with toe, which you don't need any special tools for. However, it's fairly difficult to explain how to set up an alignment rack. You'll need someone there who's at least got some basic experience in getting the vehicle set up. BTW, Mac tools sells the 93-02 f-body camber/caster adjustment tool for $100, or you could buy one from GM. If you know any GM techs you could probably borrow it. Or you could probably just use a couple of prybars, but it will probably be more difficult.
Old Dec 3, 2006 | 06:33 PM
my94blackz's Avatar
Be carefull the tools are also week. I have done three lowered camaro's and have broke three tools. Lowered cars make it hard.
Old Dec 5, 2006 | 03:39 PM
multicar's Avatar
rockauto.com has the tools too for less or you could make the tools with a turnbuckle and some sawed off hook bolts.
Doug
PublicEnemy1
Apr 7, 2015 12:21 PM
8T8IROC
Mar 26, 2015 09:02 PM
karguy16
Mar 6, 2015 01:33 AM
siguy
Nov 27, 2014 10:07 AM
