NORALTA
11-20-2006, 12:31 PM
How much of a bitch is it to swap in a 6.0 out of a truck into a 98 TA. I would like to do this and add ls6 intake, cam it, and ported ls6 heads. Any major problems or concerns here?
Those of you that have done a 6.0 block swap please chime in.
davidarel
11-20-2006, 12:47 PM
The block is the same as far as bolts and dimensions. Everything from the ls1 will go onto the 6.0L.
teke184
11-20-2006, 02:16 PM
you wouldn't really gain much over the LS1 block. a few more cubes is about it.
conversely you'll be adding 100lbs to the front of your car.
if you want more cubes you're better off going with a decent stroker short block. a nice aluminum block 382ci would work nicely with a fat 24x cam and ported heads
AL SS590 M6
11-21-2006, 10:14 AM
It'll work but the extra weight isn't worth it unless you plan on abusing it later on with a ton of spray of FI.
Like stated there isnt that much of a point, i did it in my 99 b/c the ls1 threw a rod and i got a good price on the 6.0, everything on your ls1 will swap over, you do need to drill one hole for an alternator bolt, i would recommend using higher compression heads on it, the stock lq4's were only 9.5:1 and the lq9 were 10:1.
Pm me if you need some answers to your questions.
Kyle@CSS
11-23-2006, 09:44 PM
Change the intake, oil pan, and drill the hole for the alternator. We have done many of these swaps at the shop.
Kraest
11-24-2006, 09:32 AM
Yeah, I agree.
You're going from 346 to 364 cubes. Not a huge leap, however, when (if) you do a stroker motor, that's when the fun will really begin ;)
