Chevy16
11-18-2006, 11:22 PM
just like title says for c5s going on a 96 camaro
Will 245/45/17 fit in the front?Chevy16 11-18-2006, 11:22 PM just like title says for c5s going on a 96 camaro Blue89Bird 11-18-2006, 11:44 PM My car came stock with 275's so........ Bow94z 11-19-2006, 01:33 AM yea, i dont see why not... I run my 275/40/17's (aftermarket) OR 245/50/16's (stock wheels) Chevy16 11-19-2006, 07:00 PM cool now what size tire should i throw on the back? theyre 18x9.5 Dave '97 Z28 M6 11-19-2006, 11:39 PM 275/35-18 would be a good fit for the wheels, and a close match for the height of the 245/45-17 fronts jwade95Z 11-20-2006, 01:23 PM Since the wheels are staggered, you might seriously consider going with the stock Corvette wheels sizes. 245/45 r17 & 275/40r18. I've seen the c5 wheels with Camaro sized plus 1 (17) and plus 2 (18) sized tires and they don't look proportional to each other. What I mean is that the rear tires will look a lot thinner around the rim, thereby making the front 17s look a lot thicker around the rim. The stock corvette staggered 17/18 tire sizes look to be in better proportion with one another. Something to consider. Going with the corvette sizes will make the rears taller though overall, throwing off the speedo, if that matters to you. Chevy16 11-20-2006, 03:54 PM Since the wheels are staggered, you might seriously consider going with the stock Corvette wheels sizes. 245/45 r17 & 275/40r18. I've seen the c5 wheels with Camaro sized plus 1 (17) and plus 2 (18) sized tires and they don't look proportional to each other. What I mean is that the rear tires will look a lot thinner around the rim, thereby making the front 17s look a lot thicker around the rim. The stock corvette staggered 17/18 tire sizes look to be in better proportion with one another. Something to consider. Going with the corvette sizes will make the rears taller though overall, throwing off the speedo, if that matters to you. i was actually thinking about going that way so mabye i will, how far will it throw off the speedo? jwade95Z 11-21-2006, 10:12 AM Search "tire size calculator" on here. There's one on a miata site that gets used quite a bit. partsguy 11-22-2006, 03:50 PM i have a 98 with 245/4517 on the front and 275/4018 on rear with c5 wheels.they fit perfect.my son has a 95 with 235/4517 on front and 275/3518 on rear also c5 wheels and they look good also.seem to fit fine Injuneer 11-22-2006, 06:27 PM The magnitude of the speedo/odo error depends on what tires came stock on your car. What was the stock tire on your V6? Also consider a 285/35-18, which will give you a wider tire and a slightly taller sidewall than the 275/35-18. Chevy16 11-23-2006, 01:32 AM my stockers are 235/55/16 and as long as the front sits a little bit lower and has a more agressive stance ill be happy Injuneer 11-23-2006, 10:58 AM Just remember... in addition to throwing off the speedometer and odometer (correctable with PCM programming), a tire larger than stock will have the effect of going to a lower numerical rear axle ratio. The 275/40-18 won't be all that bad if your PCM is calibrated for the 235/55-16's. The speedo will read 2% lower than actual speed (indicate 59mph at a true 60mph), and the gear ratio effect will be similar to swapping a 3.35 gear (if there was such a size) in place of a 3.42. | ||
