transAMdriv3r
11-18-2006, 12:18 PM
On my 94 ta, my passenger headlight goes down too far after use, is there anyway to limit how far it goes down?
flip up headlights questiontransAMdriv3r 11-18-2006, 12:18 PM On my 94 ta, my passenger headlight goes down too far after use, is there anyway to limit how far it goes down? mmmchickenboy 11-19-2006, 10:48 AM put the lights up then pull the fuses for the headlight motors (do this for safety; once the fuses are pulled you can turn off the headlights). then remove the headlight bezel and look around, you should be able to spot the headlight stops pretty easily. adjust the lower limit "up". transAMdriv3r 11-19-2006, 07:36 PM thank you sir :) | ||
