94_camm
11-18-2006, 10:19 AM
Any have a diagram or anything on how to hook up the mallory685 to a 94z?
Mallory 68594_camm 11-18-2006, 10:19 AM Any have a diagram or anything on how to hook up the mallory685 to a 94z? 2000GTP 11-19-2006, 12:44 PM In order to avoid cutting and splicing your factory wiring, I would purchase the MSD wire harness as well for thirty bucks. Then this is how the wires coordinate: MSD harness to Mallory 685 Red to Red Black to Black White to Green Orange to Yellow Other then that, you are just hooking up two other wires, one for the power and the other for ground. If you have a nitrous kit, you will take it a bit further as you also have wires for the timing retard and the window switch. 94_camm 12-03-2006, 06:36 PM i still dont get it...which red wire.which green wire thier like 2 or 3 of each color... 2000GTP 12-03-2006, 07:26 PM Here is a link to the instructions: http://www.centuryperformance.com/mallory/techfiles/MA1478_Hyfire6.pdf Hopefully that will help you better. 94_camm 12-16-2006, 10:35 AM ok so i got those other wires..now i need to get a map sensor 3 pin connector?were can i get one of those? then for the other green/black wire it says magnetic pick-up whats that mean?and then the last 3 wires...yellow/violet/orange...when it says 12 volt activates does the mean to the battery? then were do i put the rpm switch output to?? Sorry bout the questions not a big electrical guy! 2000GTP 12-16-2006, 10:49 AM The MAP sensor connection is not needed and neither is the magnetic pickup. There will be alot of unused wires on this box. As for the other three wires you mention, the orange wire I didn't use at all. The violet wire is for your window switch and will provide a ground. You will need to connect this to the main ground of your nitrous relay. The yellow wire needs 12 volt activation source. It does NOT mean it needs a permenent source from the battery. What you do is connect it to the 12V activation side of the nitrous relay, which can be done with a wire tap. When the nitrous system is activated, the nitrous relay will send 12V to both the nitrous/fuel solenoids and also to this wire which will initiate the timing retard. This is why you don't want to connect it directly to the battery because then the timing retard will be active all the time, something you don't want. Did you at least get the main power and ground hooked up and the four wires for the ignition coil? If you have done that, then the car should be capable of starting. I hope all this makes sense and is clear to you. 94_camm 12-16-2006, 11:01 AM yes all of those other wires are hooked up jsut needed to know were the other wires needed to go!!thanks for the help | ||
