Jay-mak
11-16-2006, 07:40 PM
Can someone help me find the codes on the vin # that tells you what the gear ratio in each camaro is? I knew once upon a time....
Vin number - gear ratioJay-mak 11-16-2006, 07:40 PM Can someone help me find the codes on the vin # that tells you what the gear ratio in each camaro is? I knew once upon a time.... Thanks 2001NBMZ28 11-16-2006, 07:47 PM RPO codes should tell you what the car came with stock. SSpdDmon 11-16-2006, 11:46 PM Yeah, check the door. There's a code that starts with "GU" that tells you what gear is in there. Capn Pete 11-17-2006, 07:51 AM GU2 - 2.73's GU5 - 3.23's GU6 - 3.42's and G80 is the code for "Limited-Slip" differential As well, some V6 cars came with 3.08's ... that may be GU4 or something? :confused: | ||
