9 inch Center Section Sale @ VRE
Eric@Victory Racing
11-16-2006, 01:52 PM
We are having a sale until January 1 for our built 9" center sections. Choose any ratio from 3.00 to 6.50 with your choice of differential or spool. Choose either a Daytona or Billet aluminum support and either a Forged or Billet pinion yoke.
Here are some common center sections that we have build in the past,
Strange S casting with Strange gear, Truetrac differential, Daytona support with a forged pinion yoke, all timken bearings assembled for $1299.99 shipped with in the 48 states! See pic for example.
http://i35.photobucket.com/albums/d186/1BAD86Z/9inchcenters004.jpg
Strange Nodular casting and gear set, 31-33-35 spline Spool, Billet aluminum support with billet pinion 1350 yoke, timken bearings assembled for $1199.99 Add $250.00 for Truetrac or Auburn, add $325.00 for Detroit locker in 31 spline. shipped with in the 48 states! See pic for example.
http://i35.photobucket.com/albums/d186/1BAD86Z/Chet9inchcenter.jpg
Ultra lite ultimate 9 inch package with a Moser through bolt casting, Strange spool 35 spl., billet pro aluminum support, any ratio from 3.50 - 6.00 on street (8620) gear, Billet 1350 pinion yoke, Mark Williams ring gear bolts, Timken bearings and assembled "in house" for $1499.99 shipped with in the 48 states! Rated well past 1000hp! See pic for example.
http://i35.photobucket.com/albums/d186/1BAD86Z/Taners9inch001.jpg
We do also offer a budget 9" using a Ford motor sport case, up to 31 spline axles, with Motive gears, Truetrac, 1330 Ford Motor Sport pinion yoke, Timken bearings assembled "in house" for 1025.00 shipped with in the 48 states. This will also include a conversion u-joint and a set of u-bolts to fit your stock driveshaft!
RealQuick
11-17-2006, 03:41 PM
Eric, I need a few of the studs that hold the center section onto the axle housing. Can I buy those thru you?
Jon
