cold fusion
Old Nov 14, 2006 | 08:03 PM
itzkwik's Avatar
cold fusion
are their products worth a crap
Old Nov 14, 2006 | 08:49 PM
2000GTP's Avatar
I haven't heard of any negative feedback about them from those that have the kits.
Old Nov 15, 2006 | 09:36 AM
Nitro Dave's Avatar
You get what you pay for....
However
For just alittle more you can get much more with a Nitrous Outlet single nozzle wet system.
499.00 gets you a bottle with a valve that will flow 800 hp. Valve also has ports for a bottle gauge and heater sensor. Quick release bottle brackets, Large 300 hp solenoids, etc. ohh and the best tech service possible...
Dave
Old Nov 15, 2006 | 09:44 AM
Ray@NitroDaves's Avatar
However
Dave
It also comes with a 16' main feed line and 2' lines to run fron the solenoid to the nozzle. That gives you more options on where to mount the bottle and solenoids
Old Nov 15, 2006 | 04:32 PM
itzkwik's Avatar
i already have 2 systems ,200 hp dry and the nos nszle that I took off but plan to work in conjunction w/ the dry sys. i just need a progressive controller, i think i am just going to go with the 2 stage nos or the new digital nx controller,i like to use stuff that has been proven to work
Old Nov 15, 2006 | 04:52 PM
Jerm93z28's Avatar
have a friend with a cold fusion direct port on his LS1 car. one of the solenoids was defective right out of the box, and their customer service was non-existant when he tried to get a replacement. (and some other stuff)
Old Nov 17, 2006 | 08:41 AM
93BlackTA's Avatar
I had the wet kit and had a problem with the NOS solenoid being defective as well, but they were quick to fix the problem for me...I was very pleased with the kit....took off 1.2 secods with a 100 shot
Old Nov 19, 2006 | 09:09 PM
Mikek340's Avatar
I have a cold fusion wet kit on my car. it's been on there for 2 years with 0 problems. We also have 2 foggers and 2 plate systems on our drag race setup up which they plummed all of it and it works with 100% perfection. if you go to there website and then plumbing services http://www.coldfusionnitrous.com/plumbing.aspx#. the custom sheet metal intake is our setup. we spray 1500hp through 3 stages and also are dealers for them. There products are promising.
Old Nov 20, 2006 | 06:32 PM
srsnow's Avatar
Just about any solenoid you get is going to be of good quality. There isn't a whole lot to a solenoid so there isn't really much that can go wrong. And if I remember right Cold Fusion got shipped a bunch of solenoids from their vendor that were supposed to be nitrous and turned out to be fuel.
Old Nov 22, 2006 | 11:38 PM
Osmosis's Avatar
Something has to be said for excellent customer service...I heard NX has great customer service as Harris speedworks and nitro dave
Old Nov 23, 2006 | 08:34 AM
2000GTP's Avatar
Yep, I have dealt with all three, and their customer service it top notch.
Old Nov 25, 2006 | 09:34 AM
HarrisSpeedWorks's Avatar
Thanks Osmosis & 2000GTP, we try to do our best!
Matt
PopoFormula
Oct 12, 2015 04:19 PM
WobblySausage
Oct 7, 2015 02:44 PM
football4life
Oct 4, 2015 07:48 AM
greenzee28
Sep 25, 2015 04:29 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
