Why are blower/turbo guys not using...
Old Nov 17, 2002 | 12:59 AM
Dr.Mudge's Avatar
The 91-93 Syclone/Typhoon PCM?
The world may never know.......
Old Nov 17, 2002 | 09:50 AM
MEAN LT1's Avatar
Now that I think about it , I dont know why. I know there computers can read boost but I didnt know the two pcm's were compatible?.
Old Nov 17, 2002 | 12:06 PM
Dr.Mudge's Avatar
They can be configured to run on a 4, 6 or 8 cylinder car. Other than that, probably not too much work adapting it to a newer car. If the VSS is not the same, well they will accept a magnetic pickup VSS.
I'll be adapting one to a 72 straight 6 car, I'm finding that other people elsewhere are using them on totally foreign cars, so I dont see why people here are not more creative, and instead crying about thier $2500 computer requirements.
Old Nov 17, 2002 | 05:55 PM
SABLT194's Avatar
Doc,
I think the hang up would be the optispark control. I've used the 730 ECM on a BBC with no problems and I'll be running the SY TY 749 ECM on a blown olds. Both are using GM HEI ignition.
Steve
Old Sep 29, 2004 | 04:38 AM
Highlander's Avatar
Re: Why are blower/turbo guys not using...
what ever happened to this?
Old Oct 21, 2004 | 01:22 PM
Geoff Chadwick's Avatar
Good question. I've heard from many that it has been done, but never found specific details for lt1's. Only TPI stuff...
http://www.speedtoys.com/~bort62/7749/Main.htm
Old Oct 21, 2004 | 02:06 PM
Alvin@pcmforless.com's Avatar
Bingo
optispark controls.
I think your best bet woudl be tuning the stock computer. If you wanted to get fancy then you can try to piggyback a 749 on a stock computer.
Old Oct 21, 2004 | 03:23 PM
Well, my desire is to get a car that doesnt need a complete re-tune every time I adjust boost. I would prefer a low boost setting for the street, and a high boost setting when I feel frisky. Now I know I CAN use an Apexi S-AFC, but that'd be a lot of effort to get the adjustments down correctly - and that doesnt solve one safety issue turbo guys have. If you get Boost creep and dont realize it instantly - how do you account for the extra air once your maf is maxed out?
You go DFI or fast. If removing the opti spark is part of the solution (which many of us would prefer anyway) and going to a crank trigger or the like, couldnt that still be an advantage?
I know far too little about piggy-backing ECU's.
Old Oct 21, 2004 | 07:33 PM
EddieP's Avatar
For LT1 owners, there is a very easy answer to that ... the 749 requires the signal from a late model GM HEI distributor =! high/low signals from the opti. You could machine your LT1 intake for a conventional distributor and go through wiring hell to install the 749 (while retaining your stock pcm around to keep the guage cluster/ect alive). Seems like a pain. A LOT of 3rd gen guys are doing the 749 swap - the pinouts are almost identical.
Old Oct 22, 2004 | 04:21 AM
SABLT194's Avatar
With the 749 you would also have to remove your MAF and switch to speed density. Not really a big drawback in my book, but it certainly adds to tuning time. Also, AFAIK, the 749 can not handle EGR controls when set to run a V8.
Steve
carguy0119
Apr 11, 2016 11:11 PM
blac94Z
29
Mar 25, 2015 04:21 PM
steve10358
Middle Atlantic
Mar 20, 2015 04:50 AM
mspennyhughes
Nov 28, 2014 03:22 PM
Red97LT1
Aug 7, 2002 05:45 PM
