Speaker questions
Old Nov 13, 2006 | 10:39 AM
camaroz28adam's Avatar
Speaker questions
What is the difference between 3 way, 2 way, and component speakers? What is a decent amount for wattage for rear 6.5" speakers?
Old Nov 13, 2006 | 12:08 PM
LS1 RULZ's Avatar
2-way speakers have a tweeter and a mid-woofer. A true 3-way would have a tweeter, midrange and woofer with each driver having it's own crossover filter. Cheap 3-way (and higher) car speakers are nothing more than a speaker with multiple tweeters. There is no band pass filter for the midrange driver so it is essentially reproducing the same frequencies as the tweeter. A quality 2-way is all you need.
Component speakers come with a much better crossover network. Most co-axials and tri-axials run the woofer full range with a capacitor connected to the tweeter to block the lows from going to it. A component set uses a high pass section for the tweeter and a low pass section for the woofer. Co-axials and tri-axials only have a capacitor as a crossover which has a shallow rate of attenuation of only 6dB per octave. Component speaker crossovers usually have at least a 2nd order crossover which attenuates frequencies at 12dB/octave. A 3rd order crossover would attenuate frequencies at 18dB/octave.
Old Nov 13, 2006 | 05:51 PM
the727kid's Avatar
What he said. ^^
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Rod Bender
Jan 1, 2015 03:18 PM
Brad 97z
Aug 10, 2002 09:58 AM
Chrisdude
Jul 24, 2002 02:25 PM
