Replacing suspension got questions
Well im getting some BMR 1" lowering springs in here this week.. I have been debating what todo my shocks/struts dont do **** except bottom out the car right now I was leaning towards some KYB replacements (they are alittle better then stock??) for now or maybe i can wait and get some blistiens... what else am I going to need if I do this I got lakewood LCA's will i need relo brackets or not because im not going that low...??
thanks
thanks
brackets are not needed, they will just help with possible wheel hop issues. not everyone experiences bad enough wheel hop to neccesitate brackets. you could easily hold off on getting them.
an adjustable panhard bar is advisable...to help center your axle side to side.
i would look into some of the SLP revalved Bilstiens. they are designed for a .75" drop...which would probably work much better than the standard valved bilsteins.
other than being cheap...never really heard anything good about the KYBs
Why do it half-assed? Really?
First the whole package isn't ideal for drag racing or handling. Springs and shocks have to work as a team. And lowering springs aren't exactly what you want for weight transfer. Some are better than others certainly, but I can't really go into that here, it's complicated.
Bilstein's can't handle those springs correctly. SLP Bilstein's can't either. While they are "valved" for lowering springs, they are for SLP springs which are not as low, nor as stiff as the BMR's.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Hurin
Dec 13, 2014 07:38 PM
