replacing fuel lines
deputydough
11-10-2006, 10:32 PM
ok, long story short. tried to weld on SFC's and caught fuel line on fire. just enough to put pin hole in it. scary moment for a few minutes. i can see where there is a connection under the car. but, where it goes up the fender does it go all the way to the engine or is there a connection somewhere hiding? how difficult is it to swap out? is the connection under the car the same as the "quick connect" fitting near the fuel rail? thanks for all help.
shoebox
11-10-2006, 10:42 PM
It's one piece from under the front seat to the intake fuel rail.
You are lucky your car did not burn to the ground. I have seen pictures of ones that have from doing the very same thing. :eek:
deputydough
11-11-2006, 09:51 AM
your right shoebox. god was definately taking care of the idiots. haha. i guess i will remove the fuel line and then weld. i guess the line just feeds through with minimum:rolleyes: effort, right?
RE AND CHERYL
11-11-2006, 10:04 AM
Just an idea. But if the line is only damaged in one spot , you could cut ou the damaged area (only an inch or so I assume) and install a compression fitting of the correct size to connect the lines back together.
I use them in air ride systems all the time and the lines are simular.
Re'
deputydough
11-11-2006, 02:09 PM
i wondered if i could just repair the area. it is a plastic feeling hose. right now it has a piece of intertube with a hose clamp. it is not leaking but i dont know how long it will hold. re and cheryl, you say you can cut the hose and place a comperssion fitting? ill look into that. not real crazy about replacing the entire line. thanks for the idea.
shoebox
11-11-2006, 03:37 PM
Repairing the damaged nylon hose is not recommended by the service manual. A potential leak in an air line is a little different than a fuel line. ;)
deputydough
11-11-2006, 11:55 PM
gotcha shoebox:thumb: going to dealer monday. i assume you can buy just one line and not have to buy all 3 as a set. they seem to be different sizes.
shoebox
11-12-2006, 12:08 AM
No, they come as a set. They are not too expensive.
Projectz28
11-12-2006, 05:46 AM
Its not woth repairing it. I damaged mine once by accident while I was working on my car. The entire piece from the connectors under the car to the engine was only $70. That was 3 years ago, but I bet its still under $100 for the whole thing.
shoebox
11-12-2006, 08:48 AM
$70? :eek:
Even now, they only list for $26.99 and wholesale is $16.00. Maybe that was $70 installed?
Projectz28
11-12-2006, 10:25 AM
Are we talking about the same part here? I'm talking about both supply, return and EVAP hard plastic lines from the motor, into the wheel well and down to the connector under the car.
Its also possible I got ripped by my local dealer;) I was in dire need of them and that was the best price I could negotiate at the time :(. I didnt know how a dealer worked back then and i probably could have gotten it cheaper but I didnt think it was under $30!!! man did I ever get raped...
Dave89IROC
11-12-2006, 10:45 AM
$70? :eek:
yeah, thats what5 they were the last time I checked
FuryZ28
11-12-2006, 12:36 PM
$70? :eek:
Might depend on the model year vehicle. Mine was $70 or $80 bucks, but my car is a 1993 model year (where GM did everything slightly different from all the other model year LT1s...)
Projectz28
11-12-2006, 12:45 PM
what? $70 or $25?
Dave89IROC
11-12-2006, 01:33 PM
what? $70 or $25?
$25-$30
Projectz28
11-12-2006, 02:34 PM
$25-$30
I must have spent too much for them then....
deputydough
11-13-2006, 10:26 AM
just ordered them at the dealer. about 25.00 for the whole set.:D
JohnnyPappis
11-13-2006, 02:02 PM
i need the plastic line that goes from the left side of the intake wraps around and goes into the fule lines i think its the evap where the hell can i find that?
Dave89IROC
11-13-2006, 05:08 PM
so it connects to the vapor line in the bundle?
I'll get you a GM part number
what year?
here is a pic from shoebox's site
is it #1 you need? the part number is there
http://shbox.com/1/1995_evap.jpg
if you have a 96-97, look here (http://shbox.com/1/1996_evap.jpg)
JohnnyPappis
11-17-2006, 04:52 PM
alright its a 94 so just pm me the part number i bearly ever get on here anymore and yeah it is i might just repace em all they all look kind worn out
Dave89IROC
11-17-2006, 05:11 PM
P/N is in the pic
