Upgrading H/C at high mileage?
Old Nov 7, 2006 | 10:17 PM
fbodylover4ever's Avatar
I will be in the market for an LS1 car in about 3 months, but my budget might only allow me something for around $7,000 which usually means high miles. I will want to do a lot of mods when I have that car, so what I want to know is, is it safe to do heads(probably the Patriot Stage 2 5.3) and a mid-size cam on an LS1 with over 100k miles? I really don't want to destroy the engine, because I would not be able to afford a rebuild. What do you guys think?
Old Nov 8, 2006 | 01:56 PM
Kraest's Avatar
Retired
If you're positive you're going to go heads/cam, I'd rebuild the motor now, then mod the car when you get more money.
Heads/Cam combos make ridiculous power on LS1s. I wouldn't push a high-mileage motor too much.
I know some guys might disagree and say the LS1 is a durable motor, which it certainly is... however, you wouldn't want to risk the chance that the motor would come apart and trash your new parts while you're spinning it to 6700 rpm, would you?
Mike
Old Nov 8, 2006 | 11:58 PM
AL SS590 M6's Avatar
Moderator
Mike
I agree.
Old Nov 12, 2006 | 08:58 PM
pHEnomIC's Avatar
Id say save up a bit more and just get a low mileage ls1.
Old Nov 12, 2006 | 10:05 PM
89TramsAmGTA's Avatar
With high milage cars and upgrading the heads and cam along with compression there is usually an increase in oil comsumption. So like was said above the best advice is rebuilding the motor. Otherwise it will be a crapshoot. Do you feel lucky?
Old Nov 14, 2006 | 09:27 AM
Kraest's Avatar
Retired
That is exactly true.
Oil consumption + aggressive heads/cam tune = Lowers octane/BOOM!
That's what happened to my buddy's car.
Mike
Old Nov 14, 2006 | 04:20 PM
DriveV8Faster's Avatar
hmm, doesn't sound promising at all. So, I guess the increase in compression would cause problems mainly. But what if I just put on a real big cam(like a T-Rex) and leave the heads stock? Would that be ok?
Old Nov 14, 2006 | 08:31 PM
Kraest's Avatar
Retired
That's exponentially worse, considering that the T-rex goes to like 7000+ rpm.
Boom goes the bottom-end.
Old Nov 15, 2006 | 03:29 PM
So I guess, just getting a mild cam is really the only option for a high mileage engine.
Old Nov 15, 2006 | 03:50 PM
2000GTP's Avatar
There is still some risk involved with just swapping the cam as well, some people have still spun bearings in their bottom ends. It wouldn't be a bad idea to set aside some money for a new shortblock in the event something does happen in the future.
Old Nov 16, 2006 | 10:25 AM
SOMSS's Avatar
I did a H/C swap at 110K and all is well. When we took the heads off everything looked new. Vertually no discernable wear. Take into account that I ordered this car and have never beaten on severely and have always used a top grade synthetic oil in my SS.
Old Nov 18, 2006 | 04:22 PM
StudyTime's Avatar
This seems like misinformation. On Thunder's website it only says it goes to 6700. You can clearly see RWHP peaks at 6300 on their website. You said 7000+, they quit the dyno pull at 6900.
Ben T.
Old Nov 19, 2006 | 08:58 AM
Moderator
Ben T.
But to maximize a 1/4 mile run with that cam you'd want to shift it at or near 7000 to keep the after shift rpm in a higher hp range.
Old Nov 19, 2006 | 11:51 AM
Vikrel's Avatar
Id rebuild first
F'n1996Z28SS
Aug 23, 2023 11:19 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
