MEATHEAD
11-16-2002, 06:20 PM
I'm at a point in a project where I need to decide between o-ringing the block or the aluminum heads. What do you guys think would be the better choice, and why?
Thanks in advance,
Shannon
Thanks in advance,
Shannon
"o-ringing"MEATHEAD 11-16-2002, 06:20 PM I'm at a point in a project where I need to decide between o-ringing the block or the aluminum heads. What do you guys think would be the better choice, and why? Thanks in advance, Shannon KTamez 11-16-2002, 08:25 PM My Block is O-Ringed without grooves in the heads. This allows me to Repair/Mill/Swap Cylinder heads in the future w/o worrying about matching up the grooves to Rings in the block. Good luck! Thomash 11-17-2002, 12:42 PM I was running an O-ringed block with no grooves in the heads. Worked OK until I got my compression over 14:1 then I had sealing problems. When I groved the heads the problem went away. | ||
