Doctor Rossi 11-06-2006, 01:00 PM Don't think this was posted, did a search for Z06 and didn't see it.
Ranger from the Vetteforums ran 10.85 @ 129.5 in a Z on DR's
On my first pass of the day, after an hour-long cool-down and change of rear tires to the BFGs, I ran a clean pass with the type of launch and 1-2 shift I’ve been looking for. Here are the splits:
60'........1.679 3650 launch rpm with a fast clutch release and fast throttle squeeze
330'......4.625
660'......7.046 102.61
1000'.....9.114
1320'...10.856 129.50
Density altitude at the time of the pass was negative 850 feet on my TAG weather station. Air temperature was 51 degrees. Barometer was excellent and humidity was low.
Track surface temperature was 60 degrees, kissed sweetly by full sun.
http://i6.photobucket.com/albums/y231/ryanro24/Ranger_1085_061104x.jpg
stars1010 11-06-2006, 01:09 PM :eek:
WOW!
96_Camaro_B4C 11-06-2006, 01:12 PM Is it bad that I'm having dirty thoughts right now?
:shock: :metal:
Narcah 11-06-2006, 01:19 PM Is that good?
GRN96WS6 11-06-2006, 01:23 PM That track is 30 mins from my house. That is a damn impressive time from that vette!
JakeRobb 11-06-2006, 01:29 PM 10.85 on drag radials doesn't really surprise me. It's an awesome time, but I was expecting someone to hit high 10's with good tires on an otherwise-stock Z06.
That said, 129.50?! That's a HUGE improvement over the trap speeds I've seen so far. Then again, you can't really ask for a better DA.
:bow:
What's the current best time on that GT500 that was first to run a 10.xxx a while back?
Oh yeah, and repost! (http://web.camaross.com/forums/showthread.php?t=483006)
Sweetred95ta 11-06-2006, 01:33 PM If that time is corrected for sea level, that run is probably around a 11.0-11.1. Awesome times though.
Loco Bandito 11-06-2006, 02:07 PM can't wait to see what i can pull off in my buddy's..
RedIrocZ-28 11-06-2006, 03:10 PM If that time is corrected for sea level, that run is probably around a 11.0-11.1. Awesome times though.
When or why would a racetrack correct for sea level on a time slip? The timeslip is what you ran. :confused:
cmg06s 11-06-2006, 03:12 PM anyone know what size drag radials?
JakeRobb 11-06-2006, 03:15 PM When or why would a racetrack correct for sea level on a time slip? The timeslip is what you ran. :confused:
I think he meant the other way around. For instance, (some) car magazines correct for sea level when they publish acceleration times. I know Car and Driver does, and if they ran a 10.85 at -850 DA, they'd publish ~11.1 (or whatever the result of the correction comes out to).
Sweetred95ta 11-06-2006, 03:17 PM When or why would a racetrack correct for sea level on a time slip? The timeslip is what you ran. :confused:
They don't correct on time slips. They give you the da so you can correct it yourself. More times than not, it's people way above sea level wanting to correct their times to get a feel for how the car compares to everyone else's across the world. When your da is negative, you're running in conditions that are better than most. Hence, the correction. It's just like dyno pulls. They have SAE and STD to correct the hp/tq rating as if the pull was in perfect weather conditions. It puts everyone on a level playing field.
Ryan's LT1 11-06-2006, 03:24 PM :eek:
What an AWESOME TIME! I'd like to run my car at that track, it's perfect!
Aklaim 11-06-2006, 04:55 PM Great time yes... but wtf is up with the reaction time?!?!
Z28Marcus 11-06-2006, 05:08 PM Great time yes... but wtf is up with the reaction time?!?!
Who cares. The guy was probably more concerned about his elapsed time and taking his time to get the launch right.
2000GTP 11-06-2006, 06:19 PM Doesn't surprise me at all, nice to see what a car like that can do when it has the benefit of traction.:)
Z284ever 11-06-2006, 07:53 PM So lemme get this straight. The GT500 gets this badass, DOHC, 4 valve, supercharged, intercooled, motor. The consortium over there with Evolution Motorsports, spends unkown dollars and hours, dyno tuning and track testing, and modding the heck out of it - and FINALLY get that 2 ton...erm...ponycar into the high 10's.
So this other guy simply drives up with his Z06, bolts up slicks to his bone stock, pushrod, normally aspirated smallblock....and does high 10's, as well.
Hmmmm....
95 Z/28 LT1 11-06-2006, 07:56 PM Get it straight, they're not slicks, they're drag radials! ;)
Hmmmm....
formula79 11-06-2006, 08:36 PM There is no way in hell MIR is 800 feet above sea level. It is within 5 minutes of the Wicomico River, and 10 minutes if the Potomac. I am willing to beet there is no place in this county that is 800 fet above sea level since it is a penninsula.
Thats my home track..been there with the GTO already:)
formula79 11-06-2006, 08:37 PM I was right...MIR is 80 feet above sea level..
http://www.mirdrag.com/v2/facts/
Z284ever 11-06-2006, 08:51 PM Get it straight, they're not slicks, they're drag radials! ;)
Doh! Even better.
dan-t 11-06-2006, 11:22 PM saw a z06 with headers run a 11.6 then 11.1 at kcir on sat..55 degree temp..nice forgot the speed..1000k miles on it..
dan-t 11-06-2006, 11:32 PM oh and he was on stock tires..
99SilverSS 11-07-2006, 03:49 AM Thats a very time time. I'm impressed with the 60ft and the 1/8 mile ET and speed 102mph yikes thats moving! What more can be said about 129mph trap speed. When you can get out of the hole like that and then let the car pull itself to a swift ET there is nothing likt it. Congrats!
90 Z28SS 11-07-2006, 05:06 AM I was wondering how long it was gonna take for the stock Z06's once the cool fall air hit . Thats awesome to hear . As intrusive as the torque management schedule is in the Z06 pcm ...congrats to Ranger , that pass took some major discipline and driving skill .
Almost a buck thirty ....can u imagine how fast these cars would be with simply removing the torque management from the PCM :eek: :cool:
Z28Marcus 11-07-2006, 11:03 AM So lemme get this straight. The GT500 gets this badass, DOHC, 4 valve, supercharged, intercooled, motor. The consortium over there with Evolution Motorsports, spends unkown dollars and hours, dyno tuning and track testing, and modding the heck out of it - and FINALLY get that 2 ton...erm...ponycar into the high 10's.
Hmmmm....
Just proves that as any smart person knows.. vehicle weight doesn't have any bearing on performance </end scrcasm> :rolleyes:
Z284ever 11-07-2006, 02:24 PM Just proves that as any smart person knows.. vehicle weight doesn't have any bearing on performance </end scrcasm> :rolleyes:
How right you are my friend. Excess weight can very easily be overcome, by just adding more power. ;) [/sarcasm]
number77 11-07-2006, 02:48 PM How right you are my friend. Excess weight can very easily be overcome, by just adding more power. ;) [/sarcasm]
Yep.
That car can only be driven to the bank...
While the Z06 can be driven into the 10's.
number77 11-07-2006, 02:49 PM How right you are my friend. Excess weight can very easily be overcome, by just adding more power. ;) [/sarcasm]
and aerodynamics[/sarcasm]
*insert anti-mustang fact*
The GT500 was limited to 155mph not for safety reasons, but because in reality it can't go much faster (aerodynamics).
bossco 11-07-2006, 09:48 PM and aerodynamics[/sarcasm]
Hey, but the manracer with its shelby body and ricer wing can go 175 with just 50 more horsepower...go figure???
bossco 11-07-2006, 09:49 PM So lemme get this straight. The GT500 gets this badass, DOHC, 4 valve, supercharged, intercooled, motor. The consortium over there with Evolution Motorsports, spends unkown dollars and hours, dyno tuning and track testing, and modding the heck out of it - and FINALLY get that 2 ton...erm...ponycar into the high 10's.
Hmmmm....
For which EVERYBODY at Ford should burn in HELL for all eternity... and thats because I am very forgiving soul ... Still want a Shelby though.
95 Z/28 LT1 11-07-2006, 09:55 PM Hey, but the manracer with its shelby body and ricer wing can go 175 with just 50 more horsepower...go figure???
Yeah, go figure. It's only $225,000 and weighs 3300 lbs too.
Klypto 11-07-2006, 09:57 PM 10s with a 100k warranty.. nuff said
number77 11-07-2006, 10:15 PM Hey, but the manracer with its shelby body and ricer wing can go 175 with just 50 more horsepower...go figure???
We've had alot of guys on this forum top out there cars. With alot less power they managed right around that same speed. ;)
bossco 11-08-2006, 09:05 PM Yeah, go figure. It's only $225,000 and weighs 3300 lbs too.
Weight has nothing to do with terminal velocity, just the amount of time it takes to get there. I'm pretty sure the Shelby could get close to or achieve the same speed, were it not for the speed limiter.
muckz 11-09-2006, 01:17 AM Is it bad that I'm having dirty thoughts right now? :eek:
Is that good? :confused:
yes. :cool:
Interesting...
