30th6
10-30-2006, 06:57 PM
ok i just put a moser 9in with 35 spline axels detroit locker and 4:11's.i also put a umi tunnelbrace adjustable torque arm with my pinion angle set to -2 degrees.now my car is wheelhopping ive tried changing tires, airpressure and ive tryed taking my rear swaybar off and that didnt help either so i put it back on.what would yall suggest to help with this? thanks joe
OBE1 95Z28
10-30-2006, 08:46 PM
Double check that you set the pinion angle correctly, it's not uncommon for folks to set it up wrong. -2 degree pinion angle should have the driveshaft and differential pinion yoke pointing slightly down like a "V".
30th6
10-31-2006, 05:00 PM
Im Positive I Got The Pinion Angle Right Anything Else I Should Look For?
mdacton
10-31-2006, 05:10 PM
i got the same rear....i never had that problem, but i did install some control arm relocation brackets from spohn. they have them for the moser rear and they fit great, they are weld in brackets.
my friend had this problem and the brackets took care of it
Bayer-Z28
11-01-2006, 08:24 PM
Why take the rear SB off?? I allways thought the front one could be taken off for strip and weight reduction... But not the rear.. A thicker SB would actually help wheel hop, along w/ a straighter launch..
If you're car is lowered I'd strongly advise the LCA RLB'S. THe LCA's should be parallel w/ the ground or pointed down slightly (from the frame to the rear)..I have almost no WH w/ my RLB's.... Stiffer shox, would help too.
30th6
11-03-2006, 08:52 AM
my car hasnt been lowered what cheap shocks do you recomend?ill try the rlc brackets and probley some shocks.
Bayer-Z28
11-03-2006, 11:07 PM
QA1's are adjustable, but not cheap... Injuneer would be able to help more on this than I would.... He's got experience w/ the ADJ shox... Prolly other people too for that matter...:think:
Dave '97 Z28 M6
11-04-2006, 11:36 AM
Yep, Relocation Brackets for your LCA's will definitely get rid of wheelhop.
