wheel need re-balancing or alignment
Unertl42
10-30-2006, 10:38 AM
I just got new g-forces mounted on the front wheels, and so last night I decidedto test them out. Well around 120-130 the car was shaking and so I decided that I had to slow down. It was definitly from the front end, so I was wondering if I just got a crappy balancing job, which by the way cost me $70 and took the morons over 3 hours, or maybe its alignment?
Z/28Camaro4life
10-30-2006, 08:58 PM
I just got new g-forces mounted on the front wheels, and so last night I decidedto test them out. Well around 120-130 the car was shaking and so I decided that I had to slow down. It was definitly from the front end, so I was wondering if I just got a crappy balancing job, which by the way cost me $70 and took the morons over 3 hours, or maybe its alignment? Was the car vibrating at 65 or it just happend at 120-130??? It is not a wheel alignment it is most likey a blanance or a bent rim. Hope this helps you out. Was it vibrating when you were braking b/c then its probably warped rotors
Remember-
pull/wheel off center = alignment
vibration= balance/bent rim
Unertl42
10-30-2006, 09:25 PM
thanks, I'll go get it rebalanced
landstuhltaylor
10-30-2006, 09:31 PM
that seems extremly expensive and a long time to get them balanced. see if they can cut you a deal.
Zack
10-30-2006, 10:15 PM
hell yea it is..****ing ripped!:eek:
