scuff.
number77
10-28-2006, 10:06 PM
My car got rearended. The guy only scuffed it, is there something that would take this out? its a scuff on plastic paneling
oneslowz28
10-29-2006, 03:40 AM
Pics would help. Try some goo gone or some 800 gritt wet sand paper. if you go the sanding route be prepaired to polish it with a buffer.
number77
11-22-2006, 06:19 PM
http://img166.imageshack.us/img166/8913/p1010388wb7.jpg (http://imageshack.us)
http://img483.imageshack.us/img483/1853/p1010387nl9.jpg (http://imageshack.us)
number77
11-24-2006, 04:42 PM
ttt
95LT1conv
11-26-2006, 02:15 PM
do you have a buffer or poligher of any kind? my suggestion would be 2000 grit wet sand (lightly) then polish with something like a porter cable 7424
number77
11-26-2006, 02:42 PM
Nope.
95LT1conv
11-27-2006, 09:06 AM
well it can still be done without a buffer, just gonna take a little longer. what have you tried so far? try a clay bar first. if that doesnt work then go to the 2000 grit wet sanding. just keep it very wet, a spray bottle will be good just keep spraying while your sanding. then use something like a Meguires deep crystal polish. without a buffer you'll just have to use a little pressure on the polish applicator.
Mikael
12-01-2006, 08:44 PM
Same idea, although i'd hit it with some 1200 grit then use a rubbing compound like 3M Medium Cut compound and a good foam polishing pad.
Little heavier duty stuff because he's doing it by hand.
