best hermonic balancer for my setup
Old Oct 22, 2006 | 08:01 PM
JohnnyPappis's Avatar
im looking for the best hermonic balancer to run with my setup a 396 HCI single turbo setup PTK kit any suggestions turbo size will be t76
Old Oct 23, 2006 | 12:43 AM
TransAm396's Avatar
Re: best hermonic balancer for my setup
how high do you plan on spinning the motor?
Old Oct 23, 2006 | 02:31 AM
7k its going to be mostly for street use not a dd but a weekend car
Old Oct 23, 2006 | 02:33 AM
TransAm396's Avatar
...go with an ATI superdamper..best in the market imho
http://thunderracing.com/catalog/?ac...vid=4&pcid=112
Old Oct 23, 2006 | 02:43 AM
also i want to clean up my acceory pullies from the ugly old stock ones because i plan on keeping everything in this car any ideas on where to go for that?
Old Oct 23, 2006 | 05:32 AM
Eric@Victory Racing's Avatar
We have the ati-917271 units on sale for $365.00 shipped if you are interested.
Old Oct 23, 2006 | 09:59 PM
roguedriver's Avatar
ATI.
Ken R.
Old Oct 23, 2006 | 10:22 PM
Purple Poncho's Avatar
Do you think that is too many CI for that turbo?? What does PTK say?
TransAm396's Avatar
yes...it is a 355 would be perfect for a t76. Your gonna need/want a t88
Old Oct 24, 2006 | 10:00 AM
RealQuick's Avatar
T4 T76 will be alittle small for 396ci, but should support 700rwhp. PTK setups only support up to a T4 T76 in size. A T88 would be the ballz for the 396 ...
Old Oct 24, 2006 | 11:00 AM
Really? They told me itd be possible with a 76 unit or thatr it would be the smallest possible unit id want to use i was considering a t 88 but like i said i had wanted to keep alll of my accesories like a/c i dont think that would be possible with a t 88 but....i guess ill find out...
Old Oct 24, 2006 | 11:30 AM
RealQuick's Avatar
You can use the T76 unit on the PTK and it is the largest that kit will fit. It is a little small for a 396, but it will still work and you'll make good numbers. A T88 is more ideal (better efficiency).
Old Oct 24, 2006 | 11:32 AM
What would you say would bethe numbers it could put out ast 15lbs of boost with a fairly large turbo cam and a set of Trick flow heads ported by LE and ported intake to match
Old Oct 24, 2006 | 12:02 PM
97ChameleonTA's Avatar
Moderator
You could always use the Innovative GT80 with the PTK kit. I believe the GT80 is the largest T4 framed turbo out there.
Old Oct 24, 2006 | 12:09 PM
RealQuick's Avatar
700rwhp @ 15psi should be doable.
Read this thread 402ci + T76
http://www.ls1tech.com/forums/showth...5752909&conly=
Parish swapped out his T76 for a T88 and went from ~700rwhp to 1000rwhp
