H4 conversion in 93-97 Firebirds....Which bulbs to use.
FLyinlow89
10-18-2006, 10:04 AM
...Yes i already searched this but most info was for camaros. Since Firebirds have sealed beams, i changed my housing to an h4 conversion. But which bulbs to i use? H4 bulbs have different prong layout than my harness.
any insight is much appreciated!
BlackbirdWS6
10-18-2006, 09:22 PM
you need to get an adapter to make the h4 lamp wire up to your factory wiring. You can pick up a couple adapters here. http://www.rallylights.com/hella/165mm_lo.asp ...at the bottom of the page.
As far as the lamps go, I chose to go with hella premium lamps but if you want to just find some at a local store..grab some silverstars.
-brian
FLyinlow89
10-18-2006, 09:50 PM
i manage a performance shop so i can get any of that crap
thanks for the info dude...i really appreciate your time!
BlackbirdWS6
10-19-2006, 10:55 AM
Not a problem. If you do happen to purchase the ones I have shown you, make sure to extend the wires since they come up a bit short with our headlights popping up and down. Haven't had a problem with mine and I'm running an H4 HID kit with them now.
-Brian
