Will a tire patch override your speed rating?
MysticTeal95Z28
10-17-2006, 01:07 PM
I know it's a dumb question, BUT, I found a screw in my driverside rear tire. :mad: If I were to get it patched, would that cause the speed rating to no longer be valid? If the tires on my car weren't so new then I wouldn't care but I just bought them and the last time I looked they were $ 81 a piece.
Mikes 1994 z28
10-17-2006, 01:25 PM
Yes, it will lower your speed rating one rating lower. Atleast thats what we told customers when I worked for Discount tire. Although IMO if you use a combination plug patch, it would affect it very much at all.
shock6906
10-17-2006, 01:35 PM
81 bucks a piece isn't that bad...but it's worth getting patched if they're pretty new still.
Red95M6Z28
10-17-2006, 03:44 PM
Here is what sold me on never patching tires......
Police cars will NOT patch tires, they buy new ones. Yes, they have obscene amounts of tax dollars to spare. Still, if the boys in blue wont patch them......Im not going to either.
B&WZ28
10-17-2006, 05:50 PM
Yes, a patch or plug or both will lower the speed rating of your tire. I just went around and around with Firestone with this same issue . I run the Wide Ovals. I got a new tire.
Spinner
10-17-2006, 06:12 PM
Which makes you more uneasy, a patch or a screw.
My .02 is that the screw presents 10,000 times a bigger threat to you then a patch does any day.
MysticTeal95Z28
10-17-2006, 07:45 PM
I don't get what you're saying, surely you don't think that I'm naive enough to leave the screw in my tire rather then get a patch? :rolleyes: I plan on getting it patched and I was just wondering if when patched, the tire would be considered a lower speed rating, not that my car would do 168 MPH or I am dumb enough to try 150-155 MPH it on a public road.
Dave '97 Z28 M6
10-18-2006, 01:49 AM
I know it's a dumb question...
It's actually not a dumb question at all. It would be great to hear what the tire manufacturers would have to say about this.
MysticTeal95Z28
10-18-2006, 12:50 PM
Well I took my wheel to a shop, the shop pulled the tire off of the wheel and luckily the screw did not go through the tire, it was just in the tread sideways, at an angle. :D I looked at the tire from the inside and it was just fine. I'm so much happier now that the screw didn't puncture the tire, he put a patch on it just to be safe.
The tire not being punctured would explain why the tire was holding the same air pressure just fine, but I wanted to make sure it was fine instead of just pulling the screw out of it.
JeremyNYR
10-18-2006, 01:48 PM
I worked at tire shops for several years while in college and remember reading about this very topic. Each manufacturer has their own guidelines/opinions with respect to this topic and related plug/patch scenarios. The guidelines on how many plugs/patches can safely be used on one tire and the required spacing between them varies by manufacturer, and each manufacturer decides if plugging/patching a tire voids the speed rating. I don't recall specific manufacturer's take on the subject, but there are definitely manufacturers that say repairing a tire voids the speed rating. I believe some say the speed rating is still valid under certain conditions (i.e. the right type of plug/patch is used and only one per tire).
From personal experience, I would be sure that a one piece plug & patch style repair is done. I think they are much better than a separate plug and/or patch. Also, it's sad how poorly most places train their employees in performing repairs. New hires off the street often times perform repairs and don't have a clue about how to do it properly.
CALL911
10-18-2006, 07:13 PM
After getting a nail through my Nitto DR, I found myself contemplating this same question. From all the experts I talked to, they pretty much came to the same conclusion that "yes" it will lower your speed rating. Most of them said the fastest I could safely drive the tire would be highway speeds only.
Even knowing this, my highway speed is a little faster than others, and I can vouch that a patched and plugged Nitto DR held fine at 165 for about 2-3 miles. Having said this, I would not reccomend it, and later (only days) I had the tire completly replaced as well because I didn't feel safe doing that on that tire on a consistant basis, especially after heating them up and racing them at the drag strip as well.
Zack
10-18-2006, 10:40 PM
gummy type plugs that service stations do are bad for tires.
make sure you get an RMA type repair. A rubber filler fills the hole, a patch is used on the inside, and a sealant is applied over the patch
thats the way we at discount tire do it, and wont touch a tire that hasnt been done the same
sc1twntrbo
10-18-2006, 11:18 PM
hell i had 8 patches in one of my kdw's once and i drove on it untill they wore down to metal and im still alive
Zepher
10-18-2006, 11:40 PM
why even bother buying Z rated tires when the speed limits are only up to 75mph in the US?
and don't say that you bring your car to the track (road course), becuase it you can afford to track your car, you can afford race tires for your track excursions. :)
btw, I patch my 555's and RII's if they get punctured, never use those plug things.
MysticTeal95Z28
10-18-2006, 11:46 PM
They're 'W' rated (168 MPH) Kumho Ecsta ASX tires in case anybody is wondering what kind of tire they are and the screw was just in the tread, it didn't puncture the tire so it is fine. :metal:
95_formula
10-24-2006, 07:12 PM
Because its fun to go over the speed limit.:D
Zepher
10-24-2006, 09:25 PM
does it make you giggle when you are putting other people at risk?:D
Dave '97 Z28 M6
10-25-2006, 02:23 AM
Posted by a guy who bragged about doing 160 on a public road:
http://web.camaross.com/forums/showpost.php?p=4094200&postcount=33
Zepher
10-25-2006, 03:37 AM
oh, you caught me. I did do 170 when I drove the Supra that is in that picture.
95_formula
10-25-2006, 10:32 AM
There usually isn't another soul on the road for miles were I like to speed, and if there is I slow down.:D
Injuneer
10-25-2006, 01:02 PM
Let's stick to the subject... if you guys want do argue, take it off line.
Z/28Camaro4life
10-27-2006, 10:47 AM
A tire patch or a patch/plug is very safe and I know many people who have track time with a patch or two in there tires. As long as the person doing the repair knows how to do it properly don't worry about voiding warranties and stuff like that. I work at a goodyear shop believe me when I say that it won't affect anything unless it is not repaired properly!
MasterEvilAce
04-10-2007, 07:31 PM
Who the **** did you get to do 8 of them?
I work at Tire Kingdom, and the most we can do is 3.
And yes, a tire patch will lower the speed rating.. but I wouldn't think about it too much unless you are seriously riding on those kinds of speeds daily (close to your speed rating).
02zl1_97ss
04-11-2007, 10:24 AM
Here in Iowa, my business does considerable work for the Iowa State Patrol. This is true here. THEY ABSOLUTELY WILL NOT PATCH A TIRE. It is replaced. They feel there is too much liability involved. If one of the officer's gets into a high speed pursuit and he blows a tire because it was repaired so.............they absolutely will not do it.
In everyday driving, patching a tire is fine and like has been said many times above, most speed limits nation wide are 75 m.p.h. or less................so a plug/patch combination should be fine. If you are driving above 75 m.p.h. on a public street, you are putting yourself and others at risk. That is what drag strips/auto cross tracks, etc. are for. :)
