Car Running Like Chit
Old Oct 16, 2006 | 07:03 PM
donZ's Avatar
I Have A 97 3.8 Car Has Been Sitting For A While
I Change The Plugs, Wires Runs A Little Better ,
But Still Running Chitty
I Check The Fuel Presure, About 42, And When I Rev It Up Goes To 50
Any Thoughts ?
Old Oct 16, 2006 | 07:46 PM
2001NBMZ28's Avatar
Re: Car Running Like Chit
Since it's been sitting (how long?) I'd run some new gas through it, some ignition cycles and see if you get any codes.
Old Oct 16, 2006 | 08:55 PM
MarcR94v6's Avatar
Seafoam may help a little.
Old Oct 17, 2006 | 02:03 PM
2000GTP's Avatar
I would change the fuel filter and put in a fresh tank of gas.
Old Oct 17, 2006 | 03:27 PM
donZ's Avatar
I WILL TRY THAT TODAY,
Old Oct 18, 2006 | 04:50 PM
donZ's Avatar
Ok,
Drained The Old Gas Out,
New Gas, Gas Filter, New Coils All Three
But Very Little Power ?????????
Old Oct 18, 2006 | 05:00 PM
2000GTP's Avatar
So there are no codes present, or an SES light? Is the car misfiring at all? Sometimes when cars sit for awhile, it makes for a nice home for varmints. Are you sure nothing has nested in your intake or chewed up any wiring?
Old Oct 18, 2006 | 06:18 PM
donZ's Avatar
There Is A Misfire Code
Took The Complete Air Cleaner Off, And Checked
Sprayed The Maf And Tb Out With Gumout?????
Old Oct 18, 2006 | 06:27 PM
2000GTP's Avatar
Is it a misfire specific to one cylinder, or is it just a general misfire code? Maybe the injectors are gummed up a little bit from the gas sitting too long. You might want to have the injectors flushed or have the car scanned further to find out exactly what the misfire code entails.
Old Oct 21, 2006 | 04:18 PM
donZ's Avatar
car is running 80% better
now the code is 0306
rechecked the plug, wire, and has a new coil pack ???????
on number 6 clyl
withen 15 seconds of turning of the check engine light,
it is back on, car is running pretty smooth,
thanks
Old Oct 23, 2006 | 12:33 AM
Don350k's Avatar
Good luck bud i had a missfire on #3 in my 96 3.8 turned out to be an intake gasket (after spending oodles on the ign system thinking that was the prob)
Don
cmdeshon
Dec 27, 2014 10:06 AM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Brent94Z
Mar 21, 2002 04:44 PM
