94 z28 with security light?
jamilz28
10-14-2006, 11:49 AM
94 z28 with security light? it wont start sometimes and the security light is on.
razor02097
10-14-2006, 12:49 PM
try cleaning the chip contacts on your key.
jamilz28
10-14-2006, 12:53 PM
it has the light on before i even get in the car
2001NBMZ28
10-14-2006, 01:38 PM
http://shbox.com/1/pass_key.html
jamilz28
10-14-2006, 02:14 PM
it does it with remote start too
shoebox
10-14-2006, 07:20 PM
As I understand it, with remote start, the key would already have to be bypassed with a resistor, so check the wiring for the bypass.
jamilz28
10-21-2006, 01:01 PM
ok i am stupid
can you explain what to do in a way that i can understand
oneslowz28
10-21-2006, 08:55 PM
What rob means is for the remote start to properly work you will have to either have the vatts (passkeyII) either tuned out of your pcm or you will have to do the vatts bypass. Robs site has a great write up on bypassing the vatts system. Check out these 2 links.
http://shbox.com/1/pass_key.jpg
http://shbox.com/1/vats_bypass.jpg
what the Vatts (passkeyII) does is it dissables your fuel pump and starter if it does not see the correct resistance from the "chip" on your key. This stops people from hotwiring your car if they try to steal it. the only way to crank the car up with the vatts working is to have your key (the one the vatts module is programed to" in the ignition.
I would suggest just following robs write up on bypassing the vatts. Or you can spend the $$ and have it tuned out of the ecm.
Dave89IROC
10-21-2006, 09:08 PM
I would not be suprised if he finds a resistor once he pulls the panels off under the column, I had one like that, i just had to solder the resistor in, and never had any more trouble
oneslowz28
10-21-2006, 09:27 PM
yes rember to solder it in. anything but soldering it can cause rf noise and / or a diffrent ohm reading thus sending a false signal to the vatts module and throwing the security light and dissableing the car.
jamilz28
10-22-2006, 05:36 PM
can pcm for less or madz28 tune it out becuase i will need a tune soon anyways
Dave89IROC
10-22-2006, 07:29 PM
yes it can be tuned out, and you will need to ground 1 wire in the dash
6SpdLT1Z
10-22-2006, 08:19 PM
yes
oneslowz28
10-22-2006, 09:48 PM
yes it can be tuned out.
