what causes
Daniel6718
10-14-2006, 02:29 AM
poping throught the rpm band on n20...
i have hsw lt1 wet kit 100 shot, bottle pressure about 900(jets rated at 1050)
ive pulled 4 5.5 and 6 degrees it seems to get a lil better each time i decrease timing and the car slows down but i think thats not the problem...ive read the plugs and they look like they are a little rich, my tr6 are gapped to .33
is it most likely that im blowing out the spark?
Moshbmx1
10-14-2006, 11:47 AM
I think the kits are jetted to be rich with fuel. Try a smaller fuel jet to get less fuel and lean it up a little. Im sure Matt from harris will give you his advice on this too. But thats what I would try
HarrisSpeedWorks
10-14-2006, 01:39 PM
Jetting was revised a while back for RWHP, so if your jets are stainless steel run the jetting that is included with the card, and it's based off of a 950 psi bottle pressure. Didn't you have an issue before with a fuel injector not being pluged back in or something along those lines? Has that been cleared up?
Thanks,
Matt
Daniel6718
10-14-2006, 02:03 PM
yes i fixed that but that was causing it to pop on motor...i fixed all the motor issues...now its doing it on n20...
HarrisSpeedWorks
10-15-2006, 06:52 PM
I would suggest trying a new set of spark plugs and gapping them tight.
Matt
Daniel6718
10-16-2006, 02:14 AM
alright...ill try to do that this week and test them out...the other night i went out when it was dark and saw a slight arcing comming from plug number 2....possibly from 4 also.. seemed to be comming from the base of the plug to the head????????
.so they might not be getting a great spark, what would cause it?
HarrisSpeedWorks
10-16-2006, 04:16 PM
I would say either your wires are not on all the way or the porcelain on the plug is cracked, but you should not be seeing any arcing.
Matt
camzaro28
10-22-2006, 05:10 PM
stock fuel pump?
i was going through the same issues a while back. popping/backfiring/surging on nitrous. then as time went by it started to do it on motor!!
first i replaced the fuel pump, that fixed some of the backfiring/popping. then i did the opti and that fixed the surging.
