Lt1 misc. parts I need:
blackouts for lt1 bird in good condition!!!
Lifter spider Bolts (x3),
water pump drive shaft retainer plate & bolts,...pending
Oil dip stick tube & oil dip stick with one bolt,...pending
Oil pressure sensor,....pending
Oil pump drive shaft screw (X1),.......pending
T. body to intake bolts (X4),.....pending
New intake manifold bolts,.....pending
Rear main seal housing with hardware,......pending
New oem lifters,
30 lb per hr svo red top's,
Pcv rubber grommit, (side of intake manifold)...pending
Pan hard bar,....pending
Steering rack and pinion with mounting hardware,.....pending
Coolant temp sensor Drivers side of block,.....pending
Guide plates,
Stock fuel tank with all the fuel lines,.....pending
Brackets that hold the hood to the hood hinges with 8 bolts,
Bolts that hold the hood struts to the hood.
1LE Ac delete pulley
Arp 12 point header bolts,
Arp head bolts, arp-134-3601 (new)
Arp main studs, arp-234-5501 (new)
Arp rod bolts, arp-134-6003 (new)
The plastic interior trim that covers the inside of the side mirror's Triangle pieces (dark color only) ebony or charcol......pending
If you have any of this stuff I will buy it, I am on a budget build up with my wife
so it may be a week or two but I will buy the parts.
Thanks,
Steve
New oem lifters,
Guide plates,
so it may be a week or two but I will buy the parts.Thanks,
Steve
Re: Lt1 misc. parts I need:
i have those, the thing is you would have to replace two of them i bought the whole set not knowing they sell them in pairs! all of them are still sealed! so i will let you get them for 30 shipped call up summit for the other two and your golden!
Originally Posted by 96badbird
ive got a formula hit in the front tell me what you still need an lets make a deal
Steve
Originally Posted by snakeatinZ
How much do you want for those header bolts?
If you want the rack and pinion I can combine shipping.
If you go back and edit your list and put a "pending" beside each item you've found, I'll tell you what I have. I won't waste time by telling you all I've got because I'm sure you already have it! That way we can ALL help you because we'll know what you still need!!
