snakeatinZ
10-11-2006, 06:50 AM
Lifter spider Bolts (x3),
water pump drive shaft retainer plate & bolts,
Oil dip stick tube & oil dip stick with one bolt,
Oil pressure sensor,
Oil pump drive shaft screw (X1),
T. body to intake bolts (X4),
New intake manifold bolts,
Pan hard bar,
Steering rack and pinion with mounting hardware,
Coolant temp sensor Drivers side of block,
Guide plates,
Stock fuel tank with all the fuel lines,
Thanks,
Steve
Pan hard bar,
Guide plates,
Thanks,
Steve
