red 95 z28 lt1
10-08-2006, 09:45 AM
trying to find a clunking noise (i had this posted in another section from a while back w/ no results)
ok ive been chasing down a clunking noise abut 2 months after i did my 12 bolt
symptoms: 1: very loud clunk/ bang when i nail the gas (any rpm any mph but not from a stop) sounds like its comming from the center or rear of car
2: clunking just when i go into O.D. in between 40- 50 but when i tap the brake while hitting the gas to get out of lock up, its gone. souds like its coming from the rear of the car
how long: the first symptom happend im guessing arond after i had my tranny built with a new 3200 stall converter.
the second symptom has been happening about 2 months after i had a moser 12 bolt installed before and after the trans was built ( i did the tranny after the 12 bolt)
what has been checked/ replaced: new poly trans mount, T/A mount, all bushings in rear to poly, new lakewood lca's, periodicly checking T/A mount on the 12 bolt, ls1 D/S w/ new u joints, new/ upgraded flexplate, exhaust is clearing everything too
what has NOT been checked/ replaced: motor mounts front end bushings shocks and springs, rear gears after or before install of 12 bolt
only thing i can think of is the backlash on the rear or slack on it but im not sure how to check it, its a moser 12 bolt 3:91 gears and a detroit true track diff 33 spline axles and upgraded 1350 series yoke
sorry for the long post but any help would be great
