E-town 2morro
smallblock458
10-07-2006, 12:23 PM
I ran my car last time and went 13.06 at 107 and broke the trany in 4th gear. I am supposed to go tomorro and try it again. Since last time I put a Rockland trans, 4:10's, SFC's, LCA's with relocating bracket's and KOOK's long tube's with a catted Y pipe. I am thinking it will go 12.70's or 80's. Anyone have any prediction's. I will post time's on monday if the weather hold's out.
myslowcamaro
10-07-2006, 12:47 PM
12.78
AL SS590 M6
10-08-2006, 08:19 AM
:( Broken rear end.:(
Buddy has a 98 that he put some boltons on with 4.10s and the best he's done is 13.00 @ 110 and he's broken the rear 3 times.
smallblock458
10-10-2006, 01:14 PM
Well I did'nt brake the 10 bolt yet. Had a best time of 12.82 at 109 with a 1.84 60 ft. It will go faster when I can get the launch and shifting a little better.
AL SS590 M6
10-11-2006, 12:55 AM
sweet
CamaroRacing12
10-11-2006, 01:09 PM
details on ur setup? is that on just bolt on's????
smallblock458
10-11-2006, 07:35 PM
Everything I have done to the car is in my signature, and on that pass I hit the rev limitter twice. I put it on the scale's after that pass and it is 3818LBS with me in it 230LBS, but it is a vert. I will be doing some more suspension work and then a cam swap and will try for a low 12.40 or high 12.30. These car's are not hard to make run well at the track but it is a fine line for me to either bog or blow the tire's away off the line.
