Just got nitro, whats the 411?
BlackBird97
10-05-2006, 02:37 AM
Hey guys, I just got an NX Kit, i'm just wondering all the basics. I have a window switch, bottle opener, heater, and everything else.
-What should I set the window switch for an A4-
-What should I do with the bottle when I store the car-
-All in all how basically do you use everything, I know a little bit but not everthing. Gentlemen, ENLIGHTEN ME!-
Thanks guys!
Moshbmx1
10-05-2006, 11:00 AM
Welcome to the nitrous craze.
I have my window switch set at 3000-5900 rpm. Id recommend not spraying before 3000 rpm. Also, do you have any way of pulling timing when you are on the bottle?
Basically how the nitrous actually gets into the intake, is first the system must be armed, bottle on etc. Then if you are running a WOT switch then it must be at WOT and at or above the set window(3000-5900rpm). Once that happens the computer must see adequate fuel pressure if you are using a fuel pressure safety switch, then if all goes well it should plant you firmly in the back of your seat :D
As far as storing the bottle, id say just take it out of the car and make sure it has some nitrous in it as it will turn into air over time but you dont want your bottle completely empty for the whole winter.
sprayedtransam
10-05-2006, 11:38 AM
Also, nitro and nitrous are not the same thing ;)
