What should I run?
SLeeper94Z
10-03-2006, 10:03 PM
Im planning on 383 stroker, Le2 heads and Custom nitrous cam..
Car will be around 3100-3200 pounds,TH350 Tranny,4500 stall,373 gear stock 10 bolt... and spraying at least a 200 shot..... Can anyone tell me what I should run in the 1/8 mile and 1/4 mile... and mph?
94 Z28
myslowcamaro
10-03-2006, 10:24 PM
what type of tire?
SLeeper94Z
10-03-2006, 10:30 PM
weld wheels, Et streets or Mt streets
Chopstix
10-04-2006, 01:18 AM
94 Z28
600+lb/ft and 10 bolt should not be uttered in the same sentence
If you get the car to hook it should run at least mid 10's @ 130
CamaroRacing12
10-04-2006, 05:55 PM
can u say busted rear ends?
TedH
10-04-2006, 06:30 PM
If it doesn't break and you hook up you should be in the sixes easily in the 1/8, however if it hooks you may be picking your rear off the ground. hopefully you have a driveshaft loop, at least a six point bar, a fire bottle, open lugnuts, a tranny shield/blanket, and maybe some wheelie bars...
