chris96camaro
10-03-2006, 04:41 PM
Where on the engine would i hook up the hose that runs to the back of the boost gauge to read the pressure? I'm only running it for the vacuum reading right now, so where would i put it on a 1998 3.8?
Boost gauge....chris96camaro 10-03-2006, 04:41 PM Where on the engine would i hook up the hose that runs to the back of the boost gauge to read the pressure? I'm only running it for the vacuum reading right now, so where would i put it on a 1998 3.8? evilundisguised 10-03-2006, 11:09 PM A manifold vacuum source, as in any vacuum line that runs from your intake manifold. Brake booster line would work well if you can find an appropriate splitter/fitting. | ||
