42lb SVO injectors good enough?
flusz28
10-03-2006, 08:09 AM
i plan to run 10 psi and wanted to know if i have to ditch my 42's for something bigger? i was pushing 8psi with 42's,single walbro and stock FPR and no problems. i'm not using a Fuel managment system for the blower either.
97WS6Pilot
10-03-2006, 11:13 AM
I can't tell if you have ported heads or not by your signature. If you do you will be close to maxing the 42 lb injectors at 12psi.:)
flusz28
10-03-2006, 11:30 AM
i think i will stick with 10psi for now and later on add more... so for 10psi would i be good?
SVTNTMR
10-03-2006, 10:33 PM
Im LS1 but making 570rwhp with 42# SVO's and 10# through an auto.
flusz28
10-04-2006, 08:37 AM
do you have two fuel pumps or a fuel pressure regulator?
97WS6SCharged
10-04-2006, 12:24 PM
Order a set of 60s from Racetronix. :)
flusz28
10-04-2006, 12:45 PM
Eric from Victory racing said i would be fine with the fuel pump,42's. but to just add a FPR.
