Pulley question
SC/TA
10-02-2006, 11:08 PM
When raising boost does it matter if you change the crank pulley or the s/c pulley. I know the s/c pulley is cheaper but I was just curious if there was any difference in performance or stress on the crank.
30thTA0525
10-03-2006, 12:03 AM
going bigger on the crank side is usually better.. give you more surface area for the belt too reduce slip problems
OBE1 95Z28
10-04-2006, 09:24 AM
Another vote for the crank pulley for the increased surface area to reduce belt slipage. I'm running the 7" crank pulley and the stock 3.3" SC pulley and see 10# of boost at 6K rpm with a Brad Brand solid intake tube and the Vortech Aftercooler.
SC/TA
10-04-2006, 11:27 AM
Thanks guys for the info. OBE1 do you have any clearence problems with the 7" pulley? It seems like it would be a little close to the fan. Thanks again
OBE1 95Z28
10-04-2006, 06:14 PM
The larger pulley only changes diameter, not it's "height" therefore it doesn't come any closer to the fans.
SC/TA
10-04-2006, 08:09 PM
I was talking about diameter. The pulley actually sits below the fan motor just a little bit. I may be wrong but it just seems like it would be real close. I know there are alot of people running the 7" pulley. I was just curious if you guys had to move the stock fan a little. OBE1 that sounds like a nice car that you have. You have any pics
OBE1 95Z28
10-05-2006, 09:35 AM
No need to relocate the stock fans. Thanks for the complement on the car; there's several photos of my ride in the May'05 Camaro Performers magazine.
