What Window switch are you guys running?
johnny3986
10-02-2006, 10:40 PM
Hey, just curious as to what window switch you guys are running and why?
Also, let me know which full throttle sensor you are running if you are running that as well. Thanks!!
Chopstix
10-03-2006, 02:08 PM
I am running the NOS mini progressive controller. It has a built in window switch and TPS sensor. Both this and the FJO box can be had for about the same price as buying the individual pieces.
2000GTP
10-03-2006, 03:01 PM
I'm using the Mallory 685 ignition box which has the built-in window switch as well as a timing retard function. As for the throttle switch, I am using the mechanical WOT switch that mounts on the throttle body and is depressed when the throttle is fully open.
