ROUDA
09-30-2006, 09:51 PM
I bought rust-oleum automotive spray can primer and was wondering if I can spray a aftermaket fiberglass hood with it. I dont know if it is a urathaine base or not. I allready sprayed real primer on it and I want to add a little more just to even it out and fill some small imperfections. Please help.
Kwiksilverz28
10-03-2006, 08:34 PM
Don't do it. Use real primer. You will use a ton of rattle cans to get enough material down to fill in spots...
ROUDA
10-04-2006, 12:07 AM
Its not to fill any thing. When I put the real primer on and I sanded it I went through into the black fiberglass when evening it out so I just want to cover the hood and sand that top cop with like 400grit quick then paint.
oneslowz28
10-13-2006, 03:22 AM
Just make sure its a high quality high build in a rattle can from a automotive paint supply store. A good can of high build will cost anywhere from 11 bucks to 25 bucks. i would shoot for the higher priced one as you do get what you pay for.
