6th gear
Old Nov 14, 2002 | 02:50 PM
jd13's Avatar
6th gear
How often do you guys use 6th gear? Obviously it's more for highway use, but do you around town guys use it when you can? I imagine that it puts a bit of stress on the drivetrain. Just wondering if I should stay away from it, or go for it when I can.
Old Nov 14, 2002 | 02:55 PM
XKnightRider's Avatar
I only use it on the freeway really.
When I'm over 55mph for any length of time.
Old Nov 14, 2002 | 03:26 PM
2k2z28's Avatar
I only use 6th on the highway as well.... but I only use it if I am going 70 or over.... because I like to keep my RPM's over 1700.. or else the engine does not run as smooth...
Old Nov 14, 2002 | 03:30 PM
bbentley40's Avatar
I generally only use it when I am driving 70 or so. So that is normally only when I am on the highway or interstate.
Old Nov 14, 2002 | 10:11 PM
SS_Thunder's Avatar
I use 6th at 60mph or higher
Old Nov 15, 2002 | 02:18 AM
Rd95Z's Avatar
I usually shift into 6 around 60-65 mph. If I leave it in 5th at that speed, the Loudmouth can get to be a bit much.
-John
Old Nov 15, 2002 | 06:41 AM
ssvegas's Avatar
Old Nov 15, 2002 | 07:35 AM
therealmagyver's Avatar
I use it on the highway. Before I put my dymanx bullet muffler also known as dynomouth I used to get slight hesitation when I accelerate a litte in 6th gear. Now after the install I don't have that problem nearly as much, so now I am in 6th gear at 55. No use in the city.
Old Nov 15, 2002 | 11:37 AM
WhiteDeathLS1's Avatar
The 4.10 gears make 6th gear much more useable IMO. I feel that it kind of offsets the loss in MPG due to the gearing.
Old Nov 15, 2002 | 11:42 AM
Me In ThAt Z's Avatar
You can use 6 gear a lot driving in the city at low speeds its like you are sitting at idle wasting no gas at all it works for me
Old Nov 15, 2002 | 12:15 PM
Dark Angel's Avatar
I use it on the highway and town.
ChrisFrez
Mar 22, 2015 07:00 PM
ChrisFrez
Feb 22, 2015 08:47 AM
ChrisFrez
Feb 15, 2015 08:12 AM
ChrisFrez
Feb 15, 2015 07:49 AM
ChrisFrez
Dec 21, 2014 09:47 PM
