Z-RATED94
09-28-2006, 10:52 AM
With 370rwhp, 3.73 gears, 2800 Vig. stall and a full weight Camaro what kind of 60ft. times should I be happy with if the car dead hooks? I hear of people cutting 1.60's. Is that possible with my set-up?
What kind of 60ft. time?Z-RATED94 09-28-2006, 10:52 AM With 370rwhp, 3.73 gears, 2800 Vig. stall and a full weight Camaro what kind of 60ft. times should I be happy with if the car dead hooks? I hear of people cutting 1.60's. Is that possible with my set-up? AL SS590 M6 09-28-2006, 11:20 AM With a dead hook mid to high 1.6s JakeRobb 09-28-2006, 11:42 AM If anything, the weak point in your setup with respect to your 60' times is your converter. 2800 might be a little low to pull a 1.6x. Then again, it's a Vig, and Vig's do good things. :D Let us know how it goes! CamaroRacing12 09-28-2006, 03:24 PM i believe anything below 1.9 would please me.... i would hope for a 1.7 or 1.8 DarkHorse 09-28-2006, 04:01 PM With 50 or more less HP than you I was cutting mid 1.7 on drag radials and the car went 12.36@110 With the supercharger and a 3800 converter (that hit around 4200) I went low 1.6's I have a full set of QA1 shocks and springs if your interested - that will get your 60's down. I sold the Z ABA383 09-28-2006, 06:58 PM Hey Dark Horse I may be interested in the QA1s/springs...I'm havibg a hard time hooking with the addition of the Kooks stepped LTs and EWP...Even the new Bogarts 275 50R15 M/T Radials are having a hard time...I'm spinning to a 1.59...My suspension guru is going to install relo brackets, check and set the pinion angle, but he suggested the QA1 set up...which springs do you have and which series of shocks are they...Thanks.. ...Zrated, you may need a bit more converter like 3600 for your set up as it sounds similar to mine:D ... --Alan Z-RATED94 10-01-2006, 04:05 PM Thanks guys. I'm still waiting for some decent weather. Just got rained out on Fri. and Sat. Today is perfect but the track is closed, go figure. :( | ||
