Rattle under car...bad cat?
Over the past couple days, I've noticed a very metallic sound coming from my car. It is definitely coming from the front end, and seems to be on the passengers side. It will go away for periods of time, and then all of the sudden just come back. It defintely doesn't sound like it is coming from inside the engine. I have also noticed a slight drop in power, and a fairly significant drop in gas mileage (3-4 mpg). Could my cat be going bad? I'm not throwing a code, but it seems like the most logical explanation to me.
Thanks,
Frank
Thanks,
Frank
Re: Rattle under car...bad cat?
Sometimes the heat sheild on the catalytic converter will pop its welds off and start to rattle. Get under there and toy with it to see if it moves around. You can either paperclip it shut if you dont have a welder, or just do what I did and rip it off.
I would put my money on either a bad heat shield or a defective cat. Those heat shields are fastened to the body with very small screws that fall victim to rust pretty easily. When I did my headers, most of the heads were snapped off.
autoxr166
Sep 25, 2015 04:21 PM
Sep 11, 2015 09:44 AM
