johnny3986
09-21-2006, 02:54 PM
So I bought a digital dual window switch through Dynotune Nitrous (I later found out that N20 Outlet or Harrisspeedworks had it), and it would drop the voltage on my relay meaning it didn't work. It didn't work the first time, and it never worked.
They resolved this issue by sending me another one, which didn't work.
A) Do any of you guys run this switch?
B) I was looking at the NX window switch coupled with a TPS switch mounted to the LT1 billet bracket.
I had the all the wires hooked up, and I have switched 30 amp relays several times.
EDIT: I just remembered, I had the power side of the solenoids to the relay...that IS the correct side? Mind you, I had the correct wires hooked to the right numbers so don't think that stupid question above undermines my wiring...because if you don't use the digital window switch, but have the system armed and just ground the wire off the relay, then it fires...but I can't get the damn thing to switch to ground.
(Basically just answer A or B)
