mjeep4x4
09-19-2006, 04:26 PM
I have a 91' Camaro with a 305 T.B.I. When I start then engine cold it takes a few seconds longer to start up than usual. Then the engine idle speed will go up and down, almost cutting off and then idling back up. It will continue to due this until it reaches operating tempature. Once the engine reaches operating temp it will idle fine. But if I am at a stop and start to drive off the engine hasatates until the car gets going. When crusing down the road or interstate it seems to run fine.
It sounds like to different problems, but both started at the same time. Please note, I have already change the fuel filter and the oxygen sensor. Also I am getting a code "44" (Lean Exhaust) from the computor. Has anyone had any vacuum part problems with these T.B.I. engines?
