How low PSI can you pulley an D1SC down too?
Old Sep 18, 2006 | 09:09 PM
HardcoreRM125's Avatar
I have a 18K mile, stock bottom ended LT1 car.
I am likely going to be buying an D1SC, with twins, and hard tubing (Instead of that chinsey flex stuff ) with a spare pulley. Right now, there is a 9PSI, and a 15PSI pulley with all related accessories.
I wanted to run it down at around 7-8PSI since I will be on the stock bottom for a little while. I understand it may last 10 miles, or 10 years, its a hit and miss thing, namely due to tuning. So that aside, I wanted to do everything else I can to still be able to run a D1SC ( Which I will need later, when I make a low comp stroker for boost ) on the stock bottom end at as low a PSI as I can get.
So anyone know if ATI makes pulleys to run in the 6-8PSI on a D1SC?
Old Sep 18, 2006 | 10:43 PM
Lonnie Pavtis's Avatar
Re: How low PSI can you pulley an D1SC down too?
I've done them at 7# without problem. 6# sould be possible as well.
Old Sep 18, 2006 | 10:53 PM
What pulleys did you need to get it down to 7? I think 6-7PSI is the safe limit on a stock bottom end, tune issues aside. There are a few guys running 6PSI non intercooled, so I think I am going to shoot for 7PSI ...
Thanks Lonnie.
Old Sep 19, 2006 | 07:57 AM
Acct 23749's Avatar
I have a 4.25'' pully somewhere in my garage...that might get you down that low.
Old Sep 19, 2006 | 12:57 PM
Selling it? Ill have to check some things out first, but if that would put me in the 7PSI range, I would be interested.
Old Sep 19, 2006 | 01:26 PM
Acct 23749's Avatar
I can sell it but i rather trade for a smaller pully...i need more boost!
I will check what size i need...hopefully the one in you kit will be what im looking for
Old Sep 19, 2006 | 07:42 PM
T/A KID's Avatar
if I remember right ATI told me run a 7.0 crank pulley and a 4.5inch Blower pulley on a stock LT1 D1SC setup to see about 5lbs.
But here is the question, what would happen with a FMIC, 90 degree Elbow on the inlet, and a FULL BOLT-on LT1 (Exhaust, 1.7RR's, EWP, Tuning, ETC) WOULD I still see about 5lbs or not???
I see the more mods you have it gives you less boost on a Given pulley setup.
I would figure that we need to find what RPM the Blower needs to spin in order to calculate the boost that is needed for a Certain boost range.
Lonnie you care to share your experiences
Old Sep 19, 2006 | 11:42 PM
Ok thanks for all the info guys.
Camarossguy2 ~ As long as the deal goes through, I will PM you and let you know so we can maybe work something out trading ...
Hopefulyl someone with a little more knowledge about ProChargers can get on here ...
And yes you do loose boost the free-er flowing the intake/heads are. Im not too concerned what the actual loss # wise will be, because ultimately, freeer flowing and forced induction = more power ... So really I guess I should have been a little more specific, I want to make some half decent gains with it, without pushing the stock bottom too hard. On an otherwise stock car I would shoot for the 7PSI range. And I figure if I loose a little boost, its no biggie.
Thanks for all the replies though everyone
Old Sep 22, 2006 | 12:23 PM
Ponyhntr's Avatar
With my car, I have mildly ported heads, 2.00/1.56 valves, ported intake, CC306 with 1.6 rockers, headers and 3" dual exhaust. With a D1SC, revving the engine to 6200, a 7.00" crank pulley, and a 4.50 blower pulley, it makes 6 psi.
On a stock engine spinning to 5700 or so, you will be about the same- 6-7 psi.
Old Sep 22, 2006 | 07:56 PM
Hmm ... OK.
I was hoping to stay right around 7-8 so I may go this route for now. I wonder if they make a pulley slightly smaller than 4.5 that will get me in the 7-8PSI range on a 7.00" crank pulley.
The 7.00" crank pulley is the pulley that comes with a D1SC LT1 kit isnt it?
Old Sep 22, 2006 | 08:31 PM
Ponyhntr's Avatar
Hmm ... OK.
Yes, ATI offers many different pulleys for the blower to make the appropriate amount of boost.
No, the D1SC comes with a 7.65" crank pulley. The 4.50 blower pulley is the largest you can put on an LT1 F-body (the upper radiator hose gets in the way), so that's why I had to go with the 7.00.
Old Sep 23, 2006 | 07:22 PM
Ahhh, I got you now.
Any idea what your getting into with a 7.65" Crank pulley, and the 4.50" blower pulley? Would that put me in the 7-8PSI range?
Old Sep 24, 2006 | 07:56 AM
Ponyhntr's Avatar
Probably, but the only real way to tell is to put it on the car and find out.
Old Sep 24, 2006 | 11:30 AM
Yea ... I hope that should put me close to where I want to be. I figure between that, using 30# SVO's,a 255, and pulling a few degrees of timing & gettin a box, I should be somewhat more "reliable" than just bolting a kit on.
I think I am going to wait until around christmas time to actually set it all up and get the car running. Then I will have all winter to possibly play around with LT1 Edit myself, or save some cash to get her dynotuned for when the weather breaks ...
Old Nov 28, 2006 | 12:13 AM
RedRyder518's Avatar
TTT...I really want to have the exact same setup as you do. Just wondering if anyone else has some opinions on this. My motor is healthy (I would do a compression check first) and I have plans in a year to do a 383 with 600 RWHP goals. Would a D1SC be the right supercharger for me?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
SpeedJunkee
Jan 27, 2015 10:02 PM
