Bayer-Z28
09-17-2006, 02:27 AM
Didn't think this was drag "Technique" so I posted here.
Is there any reason I cannot race at the track w/ my t-tops removed for weight reduction reasons?? Was having thoughts right when I woke up this morning, was thinking about emptying my car before I go to the track. The !tops would prolly be worth about 7-10 lbs, I'd immagine.
Are there rules for this?
LT1 POWR
09-17-2006, 02:40 AM
I know at the local track you have to have your top and windows up if you have a vert and your windows up if your a coupe. There were a few t-top LS1's at the track last night, they all had their t-tops on. Im not sure if they had to or not, i never asked them, but if they make you put your windows up, there is a good chance your not allowed to have your t-tops off. Safety reason, im sure. Also they probably dont want stuff flying out of your car and onto the track. A few years ago my brother in law had a 96 vert cobra and i remember him going down the track with the top down, but they have changed their rules a bit since then. Im not sure if this just applies to this track or its a NHRA rule or something. Maybe you could get someone with a rulebook to look it up for you.
twozs
09-17-2006, 07:29 AM
your kidding right? any weight reduction you"ll gain by leavind the tops off you"ll loose in areo drag with the tops off. empting the car is a good idea (each 100 pounds =.1 in time) but in a car thats shaped like a wedge why screw with it
wrd1972
09-17-2006, 08:33 AM
The drag will kill your HP.
Similar to my vert, I know I lose big HP when the top is down.
GhostZ28
09-17-2006, 01:10 PM
Yeah, for me top down at 100+mph my car is a dog.
Bayer-Z28
09-17-2006, 02:00 PM
ok... I never thought of the drag w/ the tops off idea.
As far as weight reduction, every little bit counts. But If it's a rule to leave the tops in, I'm not going to argue that.
Fine w/ me.
Stephen 87 IROC
09-17-2006, 02:26 PM
Unless your track is very lax on the rules, you can't race with the tops out as per the NHRA/IHRA rulebooks. I managed to find some Lexan tops out of a 92 Formula for my car. They cut a few pounds off.
The rules state that full bodied cars must have a full top and windshield. That means the convertibles must have the top up and T-tops must be in.
LT1 POWR
09-17-2006, 07:03 PM
Im sure you dont "lose" hp with the top down, but your mph might suffer due to the extra drag, causeing the effect of less hp.
GhostZ28
09-17-2006, 07:17 PM
I was actually thinking of making a set of plexiglass Ttops that you could swap out for the glass. It would cost me around 5 thousand to do this, but since it would only save like 10 pounds, do you think I'd have a market there?
around 5 thousand dollars for the first set, then every other one.. I cant tell or by little idea would be screwed..
GhostZ
09-17-2006, 09:51 PM
We've let cars run without tops as long as they have a full cage.
GhostZ28
09-17-2006, 11:29 PM
wow its my nemisis.. GhostZ..
GhostZ
09-19-2006, 02:30 PM
Maybe you're the reason I had to use GhostZ28 on another board :mad:
wrd1972
09-19-2006, 09:05 PM
Thats what I should have said, thanks for the clarification.
